1 - 20 of 1404 Posts
Here is a thread for those with the disease...the modding disease that is!
Post your highly tricked-out bike specs and pics.
We dont care about oil brands tire brands or just paint jobs...we want cold hard engine mods,parts replaced or modified.
This is to "help" people get the addiction or help them finding that trick bits they always dreamed of.
Let me start the thread with my specs:
1-Bodyworks
-Both fenders,lower,tank guards,fairing guards,frame covers and mid panels are QBcarbon carbon.
-Creations engine carbon covers (full size,not caps)
-Carbon screen by Apogee (bankrupt)
-Mototek/Graphicart undertail with
-Libertek diamond light and LED license plate light
-Graphicart flushmount flashers
-Rainbow reflectors in front lights housing
-Custom paint job/cleared graphics/lettering by Graphicart
-Racebolts engine/bodywork fasteners
-R7 genuine tank crests
-Vortex gas cap
-VFX adj. license plate bracket
-Motovation/Inturace R&G sliders (dont ask)
-Harri"s grips (to be replaced by the stock ones)
2-Engine/carburetion (around 170 rwhp/80ft-lbs of torque Veypor measured on the road not dyno)
-Yoshimura RS3 full system with duplex canisters removed (to be replaced,getting rusted...yikes)
-QBcarbon ramair airbox
-2 Flo-commanders with remotes
-Custom carburetors needles set by Factory from Ivan"s specs (1 of a kind)
-165 main fuel jets
-Krankvent positive crankcase pressure remover
-2 clutch diaphragms
-Dialed cams (110/100)
-Rohm adj. ignition trigger
-60 shots of NOS
-Ported,milled and cleaned head
-YEC gasket (thinnest available,lowers head a further 0.010 thou)
-YEC racing ignition box
-Nology coil wires
-APE adj. cam chain tensionner
-QBcarbon chin radiator (about 1 litre capacity)
-Quick-change oil fitting on oil pan
-Harris oil filler cap
-Home made carbon catch tank
-Scotts oil filter
-Pingel dual-outlets petcock
3-Gearing
Front: 16 Rear: 41 (193mph yellowbox corrected)
-DID HD 530 chain
4-Chassis
-Harris adj. rearsets
-PVM adj. GP clipons
-Vortex top triple clamp
-COX racing radiator guard
-Braced swingarm by yours truly
-Marchesini magnesium 5 spokes rims
-Sprocket cover by Frank (Motowizard)
-Home made GP style rear spools (not fancy,but effective)
-Home made shark guard on swingarm
-Stock home modified heel guards
5-Suspension
-Ohlins fork (to be moded shortly,blown seal)
-Ohlins shock custom moded by Stadium
-Scotts rotary damper
6-Electronic gizmos
-Techtronics quickshifter with sequential shift light (not available since 00--the shift light)
-Yellowbox speed corrector
-Veypor data aquisition hardware
-Sportvue MC1/Veypor wireless HUD display in/on helmet
-Escort 8500 radar detector with H.A.R.D. in-helmet wireless LED alert
-Dynotune digital air/fuel ratio meter
-Dynotune digital Nitrous bottle pressure meter
-Dynotune line purge kit
-Dynotune good for 400hp shot solenoids
-NOS basic kit (60 shot,will get a prog. box from Schnitz eventually)
-NOS time based controller (for 2 stages nitrous)
-VFX flashers/tail light integrator kit
-Nitrous kit solenoids LED monitors
-2 alarm systems (with 2 way remotes,2 miles range)
-DIGI gear indicator (to be removed shortly)
-Pimpgauges.com Indiglo tach face plate
-VDC electronics charging system monitor
-Vencowings LED voltmeter
-DEKA HD battery (yes,made for a Harley-Davidson)
-Fan switch overide
7-Brakes
-Beringer 6 pistons,6 pads/calipers calipers
-Beringer Aeronal cast iron disc(s) full floating endurance racing
-Carbon Lorraine carbon/carbon disc with CL carbon pads(the real stuff)
-Braketech full floating rear disc
-Carbon Lorraine pads all around
-Goodridge custom made lines with screw-on fittings
-GPTECH LLC fork-mounted thumb brake kit
-Titanium fasteners
-ISR GP fully adj. 17.5 master cylinder
-ISR fully adjustable GP clutch perch
8-Others
-Scottoiler (broken,to be replaced)
I think that is it...I may have forgotten a few things though :lol
Racing is everything
holy moly - I'd love to see some pics!
Do you have more info on your alarm system?
1 is home made: a simple mercury switch on a loud siren
The main one is a car system;
Its a Marksman (Magnadyne) MA-660M with 2 Polarstart PP6000 2ways remotes
You can remote start and pop-up your trunk with it if you want :)
Super Moderator
:hellobye My name is Kevin and I have the addiction!!!! :yesnod
Wheels -
PVM 5Y wheels
Bodywork -
Sato Racing Rear Sets
CRG Black Shorty Clutch & Brake Levers
Pro-Tek triple clamp
Dynomite Carbon Fiber Air Box Cover
GYTR Carbon Fiber Ring Insert Set
GYTR Carbon Fiber Tank Side Panels
GYTR Carbon Fiber Pipe Heat Shield
GTYR Carbon Fiber Clutch Guard
Clever Wolf Carbon Fiber Tank Pad
Clever Wolf Carbon Fiber Shark Fin
Corbin Carbon Fiber Front Seat
Gilles Chain Adjuster and Lifter Kit
Earache Bar Ends, Frame & Clutch sliders
Greggs Customs Flush Mounts
Greggs Customs Sprocket Cover
Greggs Customs Fender Eliminator
Greggs Customs Mirror Blockoffs
Dzus fastener kit
Puig DB Light Smoke Windscreen
Cox Radiator Guard
Pantera Keyless Gas Cap
Yamaha Rear Seat Cowl
Suspension -
Ohlins Steering Damper
Ohlins Road & Track Forks (SOON)
Ohlins Rear Shock (SOON)
Engine -
Akrapovic Race Carbon Fiber Full System
Dynojet Power Commander IIIusb
Factory Pro Velocity Stacks
BMC Air Filter
RK GXW 520 conversion 16/47 RRP sprockets
Brakes -
Rizoma Front & Rear Brake Reservoirs
Galfer Front & Rear Wave Rotors
Galfer Stainless Steel Front & Rear Brake Lines
Galfer HH Font Brake Pads
Electrical -
Scorpio SR-i500
Custom LED Tail Light Integrator
MeccaTune 8300k HID Kit
Acumen Digital Gear Indicator
Speedohealer v2
Libertek Micro LED Tag Light
Libertek Flasher Relay
Amber 6 LED 194 Marker Lights
I love my wife!
You guys are my heroes.
I can't say how many hours, days, weeks, months, years, I spend looking at bike websites wishing I had the bankroll to buy ANYTHING. I don't even have an exhaust. I got all happy when I broke my brake lever off because it gave me an excuse to get CRG levers.
You people are WAY out of my league, but man do I enjoy looking at your stuff.
Discussion Starter #9
Some do it in 1~2 shots,others do it in several years...like me.
Patience (waiting for deals) and not succombing to the "I want it right now" scheme as well as having a bit of money always on hand (for the deals) helps a lot.
Revelation 1:69
my name is frank and i have a problem....i have a hole at the bottom of my wallet and i do not know how to plug it... This post needs to be called "WHO IS THE BROKEST AFTER MODS!"
if your sig is listing ALL your mods, then theres no way its you! :lol hell your'e not even in the ballpark. look at martins 3000 mods!:lol :thumbup
Well....(gulp)....I just put down $3K for a set of Superbike Ohlins forks (the 2002 46mm version), including Attack triples and clip-on clamps. :scared :ugh
Should have them in the next couple of days. Couldn't pass it up! They are in great shape, and SHOULD have sold for double what I paid.
Only thing is....they're for an '04. I'm going to have to do a bit of work to get them to fit. Not to mention, I need to get monoblocks....my 100mm Goldlines won't fit.
Looks like I'm going to be selling a set of fresh R&T's (10kg spring, PPS prep) with Graves 26mm clamps, EMA brackets and Goldline calipers....
I'll post up pics when they come. :)
Discussion Starter #13
Carefull,you may end up having to brace the frame with those too rigid fork legs :)
FYI,they simply weld a plate around the inner swingarm pivot area,add a solid chunk of alum. across the frame up front and weld plates on the main spars where your bar ends aim when full lock.
heehee
Discussion Starter #14
Look who"s talking :lol
My fonts are smaller than yours,that"s why it looks bigger (the list).
:fact
My R1 eats my bank account
Hello everyone,
My name is Tony... I have an addiction. I just cant stop ;lol
heehee
:finger :D
If I need frame bracing.....I shouldn't be riding trackdays......:lol
Actually Martin, I was planning on bracing the frame eventually, even without the forks. I'm used to dirt bikes and a little frame flex, and I know road bikes need a certain amount of flex, too. Just need to find a reputable race shop (probably Lee's Cycle here in San Diego) that knows what they're doing. Making her too stiff would be bad, too.
Alright, enough with the exterior. I need to start saving for engine mods.....160+ is my goal!!!!
Cheating death in the "D"
My names ron (really am an addict/alcoholic in recovery) (clean/sober 18yrs.) . . . I traded one addiction for another :lol :lol :lol
here's my list-
CUSTOM PAINT:
Benelli Pearl Green mids
ALLOY FASTENERS:
Black Chrome D-Ring Fasteners
Black Chrome Quarter Turn Fasteners
Black Chrome Non Quarter-Turn Fasteners
BILLET ALUMINUM PARTS:
Acumen Red Ano DG8 case
Acumen Red Ano PD8 case
Pazzo Racing Shorty Levers, Black w/Gold Adjusters
Motrax Barends, Graves Barend Adapter (black ano) & CRG Barend Mirror
Gregg's Customs Satin Mirror Block-Off Plates
Kyle Pre-Load Adjusters (black ano)
Vortex Gas Cap Assembly (black ano)
Billet Bleed Nipple Caps (red ano)
Billet Valve Stem Caps (red ano)
Rizoma Black Ano Front & Rear Reservoir's
Gilles billet chain adjusters/lifters (black ano)
CARBON FIBER (Creations):
CF Engine Armor (case covers)
CARBON FIBER (Dynomite):
CF Front Fender (non-vented)
CF Front Sprocket Cover
CF Inner Fairing Panels
CF Plate/Indicator Bracket
CF V-Panel with Gold Mesh
CARBON FIBER (Magical Racing):
CF Chain Guard (shorty)
CF M1 Style Hugger (long)
CF Sprocket Guard
CF Tanksides
GRAPHICS:
David Jeffries Memorial Sticker on Tank
Removed all OEM Graphics
Tapeworks Signature (RCOrlow)
Tapeworks “YRT” Replaced R1 on Uppers & Mids
LIGHTING:
Greggs Customs Clear Flushmounts (front)
Superbrite 6 LED (red) LED Peanut Bulbs
Kellermann Micro LED Powder Coated Alloy Indicators (rear)
PIAA Super Extreme White
Plate Bolt LED Plate Light
OEM-YAMAHA:
Yamaha Seat Cowl
04 Yamaha Oil Fill Cap
PERFORMANCE PARTS:
AFAM 520 45 Alloy Rear/16 Lightened Steel Front
DID ERV2 520 Chain
Harris Clutch Protector & Frame Sliders
Harris Rearsets with CNC Heel Guards & Race Pegs
Marchesini Forged Aluminum 10 Spokes
MRA Clear Racing Screen
Acumen DG8 Digital Gear Indicator & PD8 Rev Light
Ohlins 916 Style Steering Damper & Bracket
Sato Racing Titanium Slip-On & Sato TI Hanger
Renthal Medium Racing Grips
Spiegler SST Braided lines (front & rear)
Brembo Clear Reservoir Tubing Front & Rear
Ferodo CP911 Race Pads
Pirelli Diablo's
Quick Change Oil Drain System
Sato Racing Rear Stand Spools
TITANIUM FASTENERS:
Bar-End Bolts
Brake/Clutch Lever Bolts
Chain Guard Bolts
Clip-On Bolts
Engine Casing Bolts
Exhaust Hanger Bolts
Front Axle Bolt
Front Fender Bolts
Frame Slider Bolts
Front Caliper Bolts
Front Fork Pinch Bolts
Front Rotor Bolts
Non 1/4 Turn Fairing Bolts
Rear Axle Nut
Rear Caliper Pin Slide Bolts
Rear Hugger Bolts
Rear Rotor Bolts
Rear Stand Bobbin Bolts
Reservoir Bolts
Rearset Bolts
Shark Guard Bolts
Sprocket Nuts
Steering Damper Bolts
Sub-Frame Bolts
Swinger Chain Protector Bolts
Throttle Control Bolts
Triple Clamp Bolts
Windscreen Bolts
yield
:bow :bow :bow
Mike Jones for president!!
Do any of you guys that have 30 grand tied up in mods ever take them to the track?? or even worse.. worry about pitching them down the road??
