1 - 9 of 9 Posts
New to this site with my 2001 r1. Ok my bike starts off normal on my way home I stop and get gas 3 blocks from my house everything was fine so I fill up and start my bike up everything was good and I pass one intersection and before I can get to the next everything shuts off completely my dash my lights nothing is on while I was doing like 60 n it just shut off any ideas cause I still have nothing and it's killing me
Sent from my iPad using MO Free
I checked my main fuse it was fine I even swapped it with my spare just to be certain and still nothing
Moderator
regulator/rectifier burnt out? battery might have got cooked.
Discussion Starter #6
My battery is still holding charge haven't checked the other yet
Life Beyond The Fast Lane!
If your battery is charged and you have nothing then you need to start tracing where the power disconnects with a meter. Power goes straight from your battery to the key switch. I would start there. See if the switch connector came off or check for power. Also, make sure the negative side of the battery is going to ground.
My R1 go to warp drive
Check the main ground to the frame, should be under the tank. No ground, no work
1 - 9 of 9 Posts
