Ok, so here’s the deal. I bought a 01 R1 about a week or two ago. The former owner had a mishap with the original engine, tried to repair it, blew it again and then replaced the motor with a 02-03 R1 engine. For some reason, they installed the motor but never put everything together (wiring harness, ecu, gauges, ect). The owner gave me a ton of parts to include the original motor (torn down), new head and damaged head and so on. I also have the newer 02-03 engine currently mounted in the frame right now. It needs a few parts installed (which I have) but I need a few more parts to get it started. The owner had no clue if the newer motor runs or not. I’m not a fan of keeping the 02-03 motor because it’s just not original and the way that it is mounted in the frame is not 100% secured to me. Two of the mounting points are not even used.
Now my question is...
Should I go ahead and see if I can rebuild the original motor and re-install it?
or
Should I get the missing parts (ECU, gauges, airbox, ect.) and do a engine swap?
Here is a pic of the original motor.
or
