I still don't know what is wrong with my 07 R1..........
put a NOS sticker on it and see if it helps. :bowI still don't know what is wrong with my 07 R1..........
.....+1If you're seriously contemplating internal engine damage, I would take it to a reliable shop that you trust and ask them to do a leakdown and compression test on the motor.
If you're only wondering if something is wrong you should:
- check to see if your motor is burning oil out the exhaust
- change the oil and inspect what's in the oil and filter (like pieces of steel or aluminum, or coolant)
- inspect your coolant for signs of engine oil
When you say down shifted to much what gear were you in? and what gear did you drop down to? and at what rev's and speed were you at? How many k's/miles do you have on her? Overall describe the situation when it happened if you can.Well I was riding my bike the other day.... and well down shifted maybe a little to much... causing over rev.... i started to here a noise coming from the motor so i pulled over and listened.... now its making a noise at higher RPMs that sound like a clank... bent valve...??? I mean I am not really too good at these things just like to ride...
Are you running stock gearing? If you are, it doesn't sound like you put the motor into the stratosphere, RPM wise. I thought the R-1 could reach 100mph in first?OK.. thanks for the help guys... this is what happened.... I was in 5th going around 112... and meant to shift to 3rd but messed up and hit 2nd which caused the back tire to lock up for a about 1 1/2 seconds... not sure about what the RPM's were at but I am sure they were VERY high.... I pulled in the clutch and shifted to 3rd like I wanted to and i heard what sounded like a clanking noise coming from the motor..... so i pulled over and had my brother bring the trailer.... got it home and started it up.... didn't hear nothing... revved it a bit and the sound comes when i rev it into higher RPM's the higher up i go the louder it gets.... it really sounds like a peace of metal in the motor... but it is to much linked to the RPM's to just be a peace of metal.... my brother said it kinda sounded like a valve knocking... because it is bent... what do yall think???
PLEASE HELP
No smoke, it idles fine? Seems odd that it could sound THAT bad.no sir i am not.... just the noise... at idle I don't have any sounds or anything... and it don't seem to be messing with the power of the bike... just sounds really bad... and I don't have the money to take it in.... just trying to figure it out my self...
I'm not a mechanic but I'm not sure that they can prove over-rev. Either way, if you have a really bad sound coming from the motor you need to get it fixed. It ain't gonna fix itself. Take it in and find a way to pay for the repairs. Or...don't run the bike until you have the money for repairs.yea they said that if it is over rev that it wouldn't be covered.... and sooo if i take it in and they tear it apart and thats what it is then i'm screwed.... and yea the sound is bad... lol you can call me tom. if you think you could help if you heard it.....
It did, good point.i thought 07s came with a slipper clutch
Then, theoretically, I've been wasting my time trying to troubleshoot. :lolthen overrrevving is not possible, theoretically
