So if you had a PCIIIr and the ignition map was blank, where would you start to change the ignition. The map that I downloaded from Martinc's website had the ignition retarted in the low end and advanced in the upper range. I spoke with my friend that races and he said that I needed to work on my F/A mixture before i work with timing at all. I went in and pulled all the timing changes out that were programmed into the map and really didn't tell a difference. It felt a little weaker but I was running it last at sea level and not here at home in the hills.
Is the computer capable of advancing and retarding enough to not be an issue? Where should the advance be entered? With the electronic change, it isn't like the older motors that have it or not. Is there a better part in the lower end of teh rev range where there should be some advance and then pull it out at the top end? Where does it really work best?
Thank you for the help...
Chris
BTW.. my mods are a BMC race air filter, velocity stacks,Throttle body slide stops, AIS block offs, Ivan's airbox mod, full micron serpent system and PCIIIr.
I want to get a krank vent before I dyno because I seem to throw a fair amount of oil into the airbox on the racetrack so I want to have it out of there before they put a sniffer on the dyno so that it doesn't read richer than it is because of the extra oil residue. I know it is minimal, but still.
