1 - 20 of 162 Posts
From beyond the stars
Ok so my ECU is coming home from visiting the awesome folks at SBUnlimited, a few more key mods to my bike and I will be working onto getting my number, membership and license and head out to the track. May not happen this summer but most def next season.
hmmm what number should I try getting :D
Discussion Starter #3 (Edited)
R1 pilot
I'd give the guys at SBU a call and see what they say. Do you have any error codes or anything? Did they turn the EXUP stuff off in the ECU when they flashed it?
Discussion Starter #6
I shot them an email cause I got home late, if I don't get a response via email, I'll call. I told them to do the EXUP stuff and everything else except for the QS stuff.
Have you replaced the fuel line??? The first time you lift the tank that should be done. It's almost guaranteed it's going to kink.
Really? that sux, is what I described a tell tail sign of a kinked line?
WOG
Yes, it definitely can be. Do a search here an you will see many instances of varying fueling issues attributed to a kinked line. It's a really easy and cheap fix.
R1 pilot
I didn't know the kinked line issues extended into 07-08 model years. I've had my tank off probably more then 10 time doing various things and have never had an issue with the fuel line.
Discussion Starter #13
Discussion Starter #15
Discussion Starter #18
My thoughts exactly.
Are you only having an issue with cold idle?
no, fans kick in and it still struggles to stay running and then....it cuts off :( :dunno
Discussion Starter #19
I believe that one of the items in the flash was race idle which required premium gas, still got some reg in it, could that be the reason killing the bike? Or maybe a bad coil?
Thats a shitty deal but i'm sure SBU will resolve it. I always thought r1's took premium for some reason. Gas can definitely effect how something runs so maybe drain out the reg and swap out for premium if the tune requires it. Good luck!!!
1 - 20 of 162 Posts
About this Discussion
25 Participants
TheDoctorVR46
Full Forum Listing
