Hiyas! I've just fitted some FGRT 206's to my ole 06 but have a quick question re the fork height at the upper triple tree. When I lay the new fork leg alongside the stock one, I noticed the Ohlin's unit was about 15mm longer than the OEM leg :icon_eek:
This is what has thrown me a bit. The manual says to fit the new forks at the same position/height at the triple tree as the old ones were. Correct me if I'm wrong but if I do this with a slightly longer leg - I'll essentially be raising the geometry at the front yeah? This def isn't what I'm after.
At the moment I'm just chasing stock geometry so using the OEM fork leg still in the triples, I measured the distance from the centre of the front axle to the very bottom of the lower triple and then replicated these measurements when later putting the new forks in.
Are any suspension guru's or guys running Ohlins here able to clarify if I'm on the right track to stock geometry by doing it the way I've done it?
Thanks in advance fellas!
