1 - 3 of 3 Posts
Have you hugged your R1 today?
Ok, so I'm reassembling the head on my 4XV. The manual says the installed valve spring height is 34.5 mm intake, and 34 mm for exhaust. It doesn't mention a service limit. If I can measure it, does anyone have any experience with what would be a good(safe) range to be in?
Also does anyone know of a crafty way to go about measuring the installed valve spring height.
unless you racing this and going to be sitting at red line, just install the springs. you wont have a problem. never seen these have a problem and ive run stock springs with kit ecu going to 12750rpm
Ok, thank you for the reply.
Now I can move forward with this project.
1 - 3 of 3 Posts
