i cant for the life of me get my clutch to engage.
The teeth are facing the rear of the bike. I get the teeth to engage the clutch cover. I also get the points lined up correctly. But all i'm getting is spring tension on the clutch lever.
I took the clutch cover off t replace it. I did not touch any of the clutch parts. And i noticed that the clutch push rod(4xv-16356-01), wobbles. It can flop down with ease, and be pushed and pulled in the direction of the clutch assembly, but does not come out. Is this normal? and what could be wrong? And when i take the oil cap off, i can see the spindle moving in and out when i rotate the arm that houses the cable.
I've looked at alot of forums and videos online. Nothing is really helping. Im thinking the teeth aren't catching correctly. I've spent countless hours and popped the clutch cover on and off a thousand times. No luck.
