1 - 12 of 12 Posts
Horror movie know-it-all
When i let go of the clutch slowly in first with now throttle (from a stop or in traffic), it seems like a jerking and the chain taps a bit.
Once i give a bit of throttle it's gone.
Anyone have this problem?
My CBR ate the R1
I have the exact same problem. I wish I could tell you what it was but I don't have a clue. I am sure somebody around here knows what it is. Thanks for the help in advance.:hellobye
is your clutch hub or basket getting grooves in it? you might want to check the next time you do an oil change.
Suicide Kings Racing
chain might be getting loose, your clutch might be slipping ( idoubt it), you rear wheel may not be align perfectly ( maybe)
other than that
bump
A chain will jerk and rattle when starting out if it is worn out and not lubed. Inspect the rollers on your chain (worn or loose), check it for any stretching, and look at the profile of the teeth on your sprockets. Lubing your chain will help eliminate some of the rattle but if your chain/sprockets are worn it will reoccur quickly.
1 - 12 of 12 Posts
