Okay the day has come. I finally took apart the bottom end of the motor. The verdict: water pump side of the assembley was completely seized. Caused by metal bits that came from the exploding clutch. Lots of metal bits and chunks in my oil pan, thankfully I dont think anything major happened up top. My gears might be fine too, but I really think the motor will be fine after I relplace the water pump and every seal known to man lol. This is gonna cost alot to me but its better than taking it to a shop.
I also took off the stator motor as one of my bolts for the cover was loose and I saw metal bits around that area I cleaned up. Not sure if itll cause a future issue but I plan on replacing any gear/bearing/sleeve that looks to be chipped or rashed up. Thankfully the oil itself looked clean when I drained it, not sparkly and nice and red still (motul 7100). Ill use new oil anyways. Also when I drained the coolant it was clean other than some of the fluid that came out the pipe that goes from below the headers and into the oil cooler. Its was a bit dirty but that was the only muck I saw.
Ill let you guys knows once I get the bike back together and see if theres any issues. Im hoping as soon as everything back together the bike will run like new.
Photos for reference:
And yes my oil pan has JB weld lol
