Status
Not open for further replies.
1 - 3 of 3 Posts
Hi Guys, i am a very short 5'4 inchs and needed to lower my 1999 R1 so I could touch the ground.
This done and pulled the front shock through the tipple clamp 10mm.
She rides well but problem is the rear subframe hits the tyre hugger when I carry a pillion.
I need som hep setting the rear shock to eliminate this problem.
Any assistance would be well received
Thanks G,
Changing the dogbone doesn't just affect ride height - it also changes the travel and spring rate.
How much have you lengthened it? Have you checked the sag?
It would help to increase preload when you're carrying a pillion, but it could still bottom out because the travel has changed.
1 - 3 of 3 Posts
Status
