1 - 20 of 20 Posts
Draggin chest hairs since 2008
Hey
Im gonna pick up a set of Marchenisi wheels for a 08 R1, do I need to buy anything else like a new sprocket with a new chain? Or will the wheels mount up to the factory equiptment? TIA
Premium Member
You need the hub / sprocket holder, that usually comes with the rear wheel. just make sure you get that too. sprockets etc stay the same as long as the hub / sprocket holder is for your bike.
Hey
yes you do, the bolt patter of the stock wheels is 6 the marchesinis are 5 so you do need a sprocket and see if you can find it in steal 530 pitch, if not you are going to have to do a 520 chain convertion.
call corey motomummy
or shane at mccoys
and find out if you they carry a 530 sprocket for marchesiny wheels.
and also you dont use nothing from your stock bike, the marchesinis come with everything.
check out the pics and you will see the difference in the sprocket.
and once again marchesini brings their own sprocket carrier, the only thing you use from the oem parts are the axle.
Discussion Starter · #4 ·
Great, thanks for the helpful info guys! Im gonna get in touch with corey to set me up with everything I will need
Discussion Starter · #11 ·
Bogie how much did your entire setup run you? The rotors chain sprockets and wheels? Man, this stuff gets expensive once u start adding everything up
Super Moderator
Very expensive, but it looks :boobies .
stock rotors and then a rear marchesini sprocket and you're good to go. you can use other rotors, but stock works as well. just need that marchesini sprocket. Nearly all sprocket manufacturers make a bolt pattern for a marchesini.
R1 Racing in Brazil
1 - 20 of 20 Posts
