1 - 3 of 3 Posts
Hello all does anyone know the maximum allowed amp draw when preforming a parasitic draw test please.
my bike shows 00.39 mA with the back up fuse in. when I pull the back up fuse it drops to 00.02 mA. I've traced the wire to the speedo clocks so if there is a problem it is with that. not sure if I have a problem or not but the battery dies after a couple of weeks no riding it. my charging system is fine. but battery is not connected to a tender as I have no electric in the garage.
thanks in advance
I miss my R1
That's very VERY slightly over what is recommended for vehicles... typically you should see nothing above 0.003A (0.3mA)
I wouldn't worry about it, if you're having issues I'd check the battery before worrying about that miniscule amount of draw.
1 - 3 of 3 Posts
