when i would go to ride, while idling and running on the interstate at constant speeds, everything was fine. However, when i would go to get on it, the bike would accelerate, but with hesitance and obviously not the normal rate of speed either. The bike would sort of lurch and let off, and lurch and let, and so on and so forth. although these movements were relatively smooth, they were quite noticable.
I called a local place that all my friends go to for their problems and he immediately linked the problems to the EXUP valve. So i took the tank off and stuff to get to the servo motor (i meant to say that other than solonoid in my original post.) I disconnected the two cables (following the mechanic's directions), and proceeded to turn the ignition key to on. the tach rose to 8500rpms and stopped, came back down and would do that every 10 seconds or so, indicating a problem. I took the cover off the servo motor exposing the gears. the motor would not turn very much. I got the specs and replaced the motor of fairly close specs w/ one from radio shack. i re-soldered the wired, and pluged it back in. the motor would now spin...somewhat. It would turn clockwise, then stop and got counter-clockwise, and then not move at all and the tach would immediately indicate a problem just as before. Im am now at a loss as to what to do. I dont have any money right now to take it in. Please help. If you need any more info, ill answer it. I tried to cover everything. Thanks
