So, to further inform you guys about my little problem w/the exup valve, here goes.
I replaced the motor, rewired and resoldered, and did everything right so that it would work properly.
With the servo motor taken loose and nothing attatched to it, i turned on the key to let it do its thing. The extension shaft that actually does the opening and closing of the valve will spin freely counter clockwise till a certain point and stop. If i manually move it past this point, it just spins all the way around and stops at the same point. When it stops, it keeps vibrating back and forth and back and forth, but wont move. at this point, the tach tango begins.
Obviously somehting is stuck, so to speak. yall got any ideas what to check. im really desperate to get this thing back on the road again. Thanx.
