HI everyone. Wanted to share my bike build. I bought a mangled 2016 R1S at auction last summer for pretty much the price of the engine with the intent to build it back into a R1 race build. I did all the work on this in my garage except for the head porting. This bike should be a monster on the track and I can't wait to get it out there, I am hoping its a good complement to my V4 and also faster around the track. The vast majority of the parts were sourced from Superbike Unlimited.
Powerplant/Electronics/Controls
1.New cylinders
2. New R1 rods
3. Ebay R1 crank (R1 crank is slight lighter than R1S crank)
4. New OEM rings
5. All new bearings/bolts, and a shit ton of o-rings
6. Danos Performance Superbike head package (porting/mill/cams/APE cam chain tensioner/thinner gasket)
7. Graves full titanium exhaust
8. MWR velocity stacks
9. Sprint filter
10. H2O Radiator
11. Woolich Auto-Tuning Suite with Race tools (QS/Blipper/Pit limiter/warm up), and wideband O2 sensor. Running open loop
12. Suter clutch
13. BSD racing switches
14. i2M Chrome Plus dashboard with GPS and TPMS
15. Zeta clutch lever
16. Domino quick turn throttle
17. Lithium Ion Battery
18. ECU relocated to tail
Drivetrain and Brakes
1. Vortex 520 15/43 sprockets and chain set
2. Thyssenkrupp Carbon fiber wheels
3. Brembo pistabassa floating rotors
4. Brembo GPR4RR front calipers
5. SBU rear rotor
6. Brembo underslung rear caliper
7. Brembo rear master cylinder (not installed yet)
8. Brembo RCS19 master cylinder
9. Speigler brake lines
10. FTECU ABS eliminator module
11. Michelin Power Performance Slicks (soft compound)
12. Zeta remote master cylinder aduster
Chassis/Suspension
1. Ohlins FGR250 forks
2. Ohlins TTX rear shock
3. Evol tech rear shock linkage
4. Stock swingarm
5. Evol tech super bike triple clamps with offset and rake adjustment kit
6. Evol tech clip ons
7. IMA rear sets
8. Fast frank rear quick change kit with underslung caliper bracket, light tech adjusters, chain holder, and GP lifters
9. Fast frank front axel quick change kit
10. Fast frank FGR fork wheels speed senor mount
11. Woodcraft lever protection
12. GB engine protection
13. Vortex frame sliders
14. DB holders front fairing stay
15. Ohlins manual steering damper
16. MotoXP Race fairings
I may be missing a few other things but that mostly sums it up. Last thing I need to do is go fine tune it on a dyno. Looking forward to getting it on the track soon to then tune the suspension. Plans for next winter are to possibly do a Suter swingarm, race stator, and gearbox upgrades. The Fast Frank parts are outstanding, they make pulling wheels off and chain adjustments so much easier.
1.New cylinders
2. New R1 rods
4. New OEM rings
9. Sprint filter
10. H2O Radiator
12. Suter clutch
5. SBU rear rotor
Chassis/Suspension
4. Stock swingarm
7. IMA rear sets
