1 - 5 of 5 Posts
I fcuk bitches bigger than you
can someone scan the CLUTCH BASKET ASSY. PAGE(S) out of their shop manuel for me, and give me the torque specs for the basket nut and the 6 outer spring bolts for a 2000 R1
email me back at
[email protected]
THANX!:jump
you can find the shop manuals if you go to the mechanical section and check out the "manuals" sticky.
I've worked on the R1 a ****load, so from memory I can tell you the clutch spring bolts are 8 N/M, and the clutch hub nut is going to be very tight, probably somewhere in the 80-110 N/M range.
1 - 5 of 5 Posts
