1 - 1 of 1 Posts
· Steeringdamper?? I´m strong...
Got a problem and asking you guys for help!
This is a little difficult to explaine without the circuit diagram. (tried to post it here but you don´t see anything, to small.)
Anyway, trying to put a -99 left handle turnsignal/headlight dimmer/horn switch to a -00 R1.
First the headlight turned on when I hit the turn signals button and the turn signal relay klicked when I hit the horn button... LOL.. managed to fix that and now everything is working exept the dimmer switch.
On the -99 you got the followin wiring:
blue/black, brown, black, brown/white and red/yellow.
From the -00 I´ve got the same exept for the BLUE/BLACK wire. When I look at the -99 circuit diagram that one goes straight to the lights switch.
Easy I thought, just put the blue/black directly to the red/yellow, that according to the -00 circuit diagram goes directly to the headlight relay.
NO, didn´t work. Headlight goes on without touching the switch and turn signals went nuts.
Do I have to put the blue/black in to the light switch (right hand side) or in to the headlight relay?
If they just took the blue/black wire away on the -00 you must be able to get everything to work with the remaining wires?
Please, if any of you are any good with reading circuit diagrams (I´m not!) I´ll e-mail them to you and explain further.
TELL ME WHERE TO PUT THE BLUE/BLACK WIRE!!!
Thanks!
1 - 1 of 1 Posts
