Ok guys I need some help here I have been having the tango tach problem but the only thing its not like the normal tango tach that every1 gets. Mines only does it some time morst of the time it will happen on the hwy, it will just jump from 3000 to 4000 rpm and then go back to normal for like a little while but I get no code or check engine light. I removed the servo and looked inside and two of the wires were touching the red and green but when I put it back I smashed the wires again and only then did my check engine light come on and the code 17 flashed. So I put in a sam's servo sub and code 17 and check engine light went away but the tach still tangos at that same rpm, could it be the connection at the engine?
P.S. Sorry this is kind of long.
