1 - 6 of 6 Posts
· Bollocks.
hey,i have had my network working fine for 6 months. i have 2 computers on my network, a laptop and a PC(host). for some uknown reason i cannot access the PC from the laptop anymore. It just stopped working!
it says i dont have acces, to contact administrator, etc...the usual msg.
i have tried everything that i can think of. i have dont netork setup loads of times, done windows trouble shoot, deinstalled...reinstalled the lan cards on botch the PC and Laptop but to no evaill
anyone got any ideas?
thanx fellas
heres a dude who has had the exact same problem as me.
http://www.computing.net/networking...orum/19117.html
· Tap dat...
[email protected]@alltimes said:
can u ping the host from the laptop? What OS are you running on the Host/laptop? If it's W2K server, and your running a domain policy, u may have to reset the password on the laptop if your logging in on a domain....let us know
:iamwithst
Need more info.
Oh...here's fjorns standard answer:
Use Linux. :finger
· Bollocks.
Discussion Starter · #4 ·
running XP pro, theres no server neither its just a simple direct cable connection. Did that help???
thanks
Id actually try linux but alot of my progs wudnt work on it im affraid
· Life: Comedy or Tragedy?
Wolf-R1 said:
Need more info.
Use Linux. :finger
:lol :lol
I'm not that predictable...
By direct cable connection, are you referring to using a null modem cable for the connection between the pc's? Or, a LAN cable between the two with NIC's?
By any chance is one or both of them setup with a DHCP address? If so, it might have changed.
NT/2000/XP:
From a command prompt type in: ipconfig
9x/Me:
From command or run line, type in: winipcfg
Whatever the IP address is on each box, try and ping that from the other.
If you get a timed out response, or something saying that nothing is working then you may need to look into drivers, or go so far as to completely remove your network stack and recreate it.
BTW, a great way to try linux is to download Knoppix. It's a cd-run, full-blown linux distrobution. :thumbup If you want to go further than that, you can install it onto either a separate partition or HDD. As to programs not working on Linux, we can address that if you decide to switch. :yesnod
How's that Wolf? I didn't say "Use Linux" ;)
1 - 6 of 6 Posts
