1 - 3 of 3 Posts
well i managed to install my next undertail with only a few hole alignment issues but i can't figure out how the plate is supposed to bolt onto their bracket. the bracket holes are about an inch closer together than the ones on my plate and the bracket doesn't come down far enough to prevent the plate hitting the lower part of the undertail yet the pictures on their site show the plate being mounted using the wider stock plate holes. Am i missing a something?
Super Moderator
Yes. remove the stock piece from the stock fender. It unbolts from the back and it'll line up and lower the plate just enough.
thanks for the help corny. unfortunately i chucked that whole deal couple years ago when i had a competition werkes unit installed so i'll have to cut up the plate a bit to make things fit till the end of the season when i can try and track down the stock piece you mentioned. anyone out there throwing away a stock fender?
1 - 3 of 3 Posts
