1 - 4 of 4 Posts
Track Junkie
Hey, I have the dessault next undertail and have a lil problem. Only half of my right blinker lights up. Could the led's be burned out already? I have only had the undertail for a month or so. I would think if they burned out the whole blinker would not work, but like I said half of it lights up......and Ideas????
Thanks for any info. :bow
Super Moderator
Is it the Graphic Art Design Next Undertail you have? Mine has
six LED's per side for the signals. Obviously you have power to it.
The LED's shouldn't be burn out since they will last much much
longer than regular bulbs. Maybe the leads that supply power to
those LED's that are not lighting up could be broken or pinched
or burnt. If you've only had it a month I'd call and see if you
could get it exchanged for another one. You might check your
voltage output to make sure you don't have any surges or spikes
Track Junkie
Yep it is the graphic Art Design undertail. I'm gonna pull it apart tomorrow and see how the leads look. Three of the leds are lit, and 3 are out on the one side.....so I doubt all 3 leds burned out.
Thanks for the suggestions, I'll see what I come up with tomorrow.
Boxing21,
I'd have to agree with Skeeter.
I've only had mine on for a couple days. I'm hoping I won't encounter this problem. Let me know what you find out though. I'd be interested in what you find.
-MotoFanatic
1 - 4 of 4 Posts
