1 - 7 of 7 Posts
I have a salvaged 2002 and trying to get it back on the road. It indoed into a pick up truck and came down moderately on it's left side. Everything is connected and all I get is a neutral light on the speedo display. I have replaced all boxes and sensors with another 2002 and still nothing. Not even a click on the fuel pump. What could I have missed.
Discussion Starter #4
Fuses are fine. Bike will not start. When key is turned to "ON" possition, absolutely nothing happens but the neutral light will come on. All else seems to be working fine. I have replaced the speedo panel, CDI and all sensors surounding the battery from another bike. It's got to be a wire problem. Are there any problems with going down on the right side with these things in terms of connections being exposed?
Premium Member
R1Budha said:
Mybe the sidesatnd switch as well?
I don't know if it prevent fuel pump opration.
the sidestand will not affect the pump...the bikes will run when the stand is down, just cant put them in gear
1 - 7 of 7 Posts
