I just bought a used Ohlins 46 PRC rear shock for my 2006 R1.
I have been reading for more than an hour now, and i can't figure out if this shock is sprung properly for me. The seller thought it was, but from what I have been reading, I think it might be too stiff.
Can you please point me to a spring chart for Ohlins' shocks, or otherwise help me figure out what the proper spring for my application is?
I couldn't find anything helpful on the Ohlins web site.
The Racetech web site says:
"Rider Weight: 170 lbs
Recommended Spring Rate for Street: 8.63 kg/mm (use closest available)
Stock Shock Spring Rate (measured): 8.6 kg/mm (stock)"
But I am too ignorant to know how to apply that...
I weigh 170 Lbs out of the shower, so probably 185 in full gear.
The text on the spring says 01093-36/105 L134
Thank you. I really appreciate your help!!!
