1 - 6 of 6 Posts
:fork Hey everyone, new to the forum. Anyway...just did my second oil change on my 03 r1. I used the silkolene comp4 10-40 semi-synthetic oil. problem is that after I finished the oil change and went to put my bike away, I realized that when shifting into first...it shifts hard, real hard. I then went to put it into neutral and it took a while for it to find neutral. Again I tried to shift it into first,and it took 4-5 attempts to get it into first. It did not shift like this when I was running the regular yamalube oil. Anybody out there offer any suggestions. I was told that the silkolene was good oil. Thanks.
WUZ-UP !
I put motul semi syn in my '02, works great ! Did you check your oil level ?
Thanks for the reply everyone. I did check the oil level and it was good. I used almost 3 1/2 qts. I didnt ride the bike yet because it was a little cold around here, but I will just let it soak in and see what happens. Thanks.
1 - 6 of 6 Posts
