1 - 16 of 16 Posts
pavement tester....
FYI, did a search and got nothing....
Here's the situation. I'm changing my plugs. THe last one I'm working on is the #4 I believe, the one on the right side. There is something down in the hole that wont let me get my wrench on the socket to take the plug out. I've looked in there with a mirror and its small, and only takes up maybe 1/4 inch of space on one side of the plug, and it is only about 1/4 inch tall. Its small, but is in the way. Its not metallic, a magnetic retriever wont work. I have no idea how it got in there, but thats not the issue now.
I've tried everything guys. 4 hours today spent on trying to get it out. DO you know how frustrating that can be????? Here's the catch. Those of you that have changed your plugs know this. The #4 isnt as bad as the #1 plug but its still almost under the frame, so you cant see directly down into it. Thats why I had to use a mirror. Also, this prevents long tools from being used because you only have about 6 inches of play above the hole to work with...
I've tried:
1-long screwdrivers
2-long screwdrivers with sticky stuff on the end
3-homemade long tweezers made out of a hanger
4-a vacuum cleaner with a hose
5-a pick much like a dentist would use
6-needle nose pliers
I'm really at a loss here. If I cant get it worked out I guess I'll just have 3 good plugs and one old one:rant Oh yea, and if you are using the mirror to look down in there, of course your hand blocks your view when working so its no good.:cryin
Any thoughts here?
Formley known as slutty
clothshanger with bubblicious gum on the end.........this stuff is so stickey it wont come off the hanger but mingt pick up the piece....
also maybe rig a small vacume line hooked up to a shope vac.
Track Junkie
Air compressor....maybe if you blow some air in there it will 'free' up what ever it is that is obstructing the plug. It's a long shot...but who knows.:dunno
Can i bum $1
some C4 explosives. Man I've got to change my plugs shortly I hope I don't run into this. I get frustrated really easily sometimes.
pavement tester....
hmm, I like the air compressor gig. Never thought of it. The bubble gum? Wont that get caught in the cylinder?
is the spark plug OUT????
is it loose?????
you dont use a whole pack just a little glob to cover the end of the hanger......
pavement tester....
Discussion Starter #7
no, spark plug is still tight. Whatever it is its preventing the socket from connecting with the nut on the plug. I dont want to pull the plug anyways for fear of that falling down into the hole farther.
I'll give it a shot
Maybe fill the plug hole up with water......if its non ferrous metal it should flot to the top......then just blow the water out with an air gun.
My R1 eats out women
pebbles
I've had a few pebbles in there too. You are always supposed to blow out the holes before removing spark plugs anyway.
DAMNED HELICOPTERS !!!
Re: pebbles
Thought this was common knowledge.
pavement tester....
Discussion Starter #11
Re: Re: pebbles
:bow
maybe Albert Einstein thought that the theory of relativity was common knowledge as well, but we all know its not:sneaky
Oh yea, some of us dont have air compressors handy in our garages either;) Thanks for the tips though
DAMN YOU SHANE
tom is right htat is what i would have said get them at autozone or my job advance auto
pavement tester....
Discussion Starter #14
nice, I'll have to check into that too
its probably a small stone (rock) with tar on it. start the engine up minus panels etc so the stone isnt stuck to the engine and try compressed air to dislodge it.
Re: Re: Re: pebbles
KneeDragger77 said:
:bow
SORRY K.D. didn"t mean to sound like an arsehole,just adding my ten penneth,seems to me that you"ve tried pretty much everything mate,all i can add is that if you "set-up" a mirror with a light pointed at the mirror and "bouncing" onto the plug hole [hands free] then get yourself a stool or something and only when you are nice and comfy,persevere with your hanger with a nice short 90 gegree bend and work at it, GOOD LUCK MATE.
1 - 16 of 16 Posts
