1 - 5 of 5 Posts
Track Junkie
Pc3r just came in.....heres my question. I was trying to install the map before i installed the unit on my bike....I have the 9v adapter, but when I go to upload the map, it's saying "can't find power commander". So, does it have to be hooked up to the bike for my computer to find it? I may be wrong, but I thought that is what the 9volt adapter was for?
Track Junkie
thats what i was thinking...thanks!!!
You are right that is what the 9volt adapter is for. It allows the unit to load maps without being connected to a bike. If the Power Commander is not being found it is because of the connection not being seen. Make sure your serial ports are active, have seen cases where they are disabled in the bios. Try the diffrent settings for the com ports also but auto should work.
Larry
1 - 5 of 5 Posts
