1 - 3 of 3 Posts
· 15,000 Feet and falling....
Can someone answer these general questions for me. I have already done a search and checked out the Dynojet website.
1) If you have a PCIII, should you get an aftermarket airfilter? Velocity Stacks? or anything else?
2) Once it's installed on your bike will you ever need to make adjustments after you have your desired map?
Any other tips would be great.
Thanks for your help:boobies
Discussion Starter · #2 ·
:hellobye
· stuntin aint easy
if you get an aftermarket filter i was told you need the map to go with it you can buy velocity stacks also but each time you add something you need to map it to work with it hope this helps
1 - 3 of 3 Posts
