i have been po'd about the amount of slack in the shifter rod sticking out of t he trany, and ive been hitting false neutral because im not lifting up on the shifter hard enough since i have lost alot if range of motion in my left ankle
so i decided to try GP shift again so i could a better upshift by pushing down on the lever instead. i started changing it (i use a gilles rear set BTW), and i think SHII_IIIIIT, im going to have to buy a push type power shifter solenoid. I go ahead and swap to gp shift and i find that because the reverse pattern is being done after the main shift arm, i can use the pull type power shifter wether im gp or standard shift. :dundun:
way to go gilles:jump
