1 - 7 of 7 Posts
· My R1 kicks my azz!!!
Anyone feel a poping noise/feeling in there 2002 R1 in the handle bars when u go over small bumps at small speed? I seem to feel it some when i first hit the front brake at low speed too. Feels like the forks are loose or sloopy. Do i need to tighten something or look at something? Its not that bad , It might be normal ,but i dont remember feeling it before. Maybe ill just take it in to my FINE OUTSTANDING ( cough cough) Yamaha service dept and let them look at it! Thanks in advance for any info!!
· Registered
Maybe it's all that lovely feedback from the forks on the 2002?
Mine had loose head bearings and the mechanics said it was the brake pads knocking,to which I said why does it do it over road bumps then!!!
The head bearings were torqued correctly but were loose maybe this is your problem?
· Registered
Stoopstroop said:
Thanks guys for the info !!! How do you tighten the head bearings? I tried moving the front forks....no movement..... that i could feel....is that what you guys are talking about? Thanks brothas :boobies :boobies
First check if they are loose by sitting on the bike and putting the front brake on, then try to push the forks down is if you hear a clunk.
From experience of my 750 I had to remove the top yoke, lock tag and locking collar I don’t know about R1’s (It’s raining and not going out to look) . Then using a ring spanner, nip it up but not too tight or the steering will be tight. Yamaha do a spanner you can attach a torque wrench to but it’s quite pricey.
Personally I’d pop it down to your bike dealers and get them to do it because your bikes under warranty.
· My R1 ate my R6
My 02 has this little pop also, and so does a friend of mine's.
Discussion Starter · #7 ·
Fixed it .........I think!! I took it to my WONDERFULL yammmy dealer and they acted like I was F%@#&*$ stupid and didnt know what I was feeling. So I told them they were probably right and since they are sooooooo helpful and everything but it wasnt doing it for the first 1100 miles I put on it! Their reply was well.....its probably getting the fronk forks broken in. So I said I hope you guys are right after all its under warranty and you guys get to fix it if it isnt! So they brought their suspension Guru out to talk to me. He, by the way, was alot nicer and more helpfull than the smartazz service manager! He suggested that I might have a missaligned front wheel by a hard hit or hard landing... HA HA!! He took it back and loosend the front wheel hub assembly and restraightned it for me. He told me he felt it pop back in when he loosened the screws. So this made me feel alot better and I thanked him for his trouble since he was the only one that treated me like a valued customer not a 16 year old kid!! ANYWAY.........that all seemed to take the poping feeling over the small bumps out !!! :rock So I hope this helps you guys if you have the same problem and maybe wont have to deal with dickhead service managers:mad:
1 - 7 of 7 Posts
