I recently started power wheelies because I heard bouncing it up is no good for the bike. It comes up quick in 1st gear, cant figure out 2nd yet. I can't hold it for too long and it comes down pretty hard. Today the front stay cracked, so that is like $100 dollar wheelie! Veteran riders give me some tips.....Thanks!!
R.I.P Evel Kneivel!!!!!!
I'm no veteran but I'll give my 2 cents:
I went +2 on back sprocket, 1st it comes up when I WOT it.
I would suggest 7K, give some throttle and slip the clutch. Do this sitting normally so you can get the feel.
Slide your weight back and do the same, it should come up a bit.
Now put your as way as far back as you can, grip the tank with your knees (will save your balls when you come down) and give a tug on the bar, it should come up easily. Don't hang with your arms - relax them, hold the tank with your legs and feet firmly on the pegs.
It's sh*t scary in the beginning, so if you snap of the throttle it's gonna come down hard (cracking your stay)
Go slowly off the throttle and ALWAYS cover your rear break, that will save you from flipping it.
The balance point comes with practice, practice and practice :fact
:fork Ride Safe and Respect the beast :rock
