1 - 20 of 48 Posts
Not sure if this is the right forum but anyone have a Throttle Meister on their R1? I do quite a bit long distance riding and had a vista cruise on my RR so looking for some throttle lock for my 05 R1.
Looking for feedback from anyone that has a throttle meister or something similar, what do you think of it, good bad and ugly, and pictures of it if possible. Thanks!
Premium Member
man i just use a crampbuster
I loved my throttlemeister on my 08. I emailed throttlemeister about a 09 application and havent heard anything back yet. But yes they are great if you go for long highway rides.
False. Black bear.
i have one. the 12oz matte black ones. first off, i love how heavy of a barend it is. second, left hand riding and being able to switch it up is amazing. only thing that i did i wouldnt recomend is using it with the driven d3 grips. i made it work.. but it works much better with standard grips.
pretty easy to install... just dont forget the locktite.
my roommate has one too.. his worked so well, i bought mine. :thumbup
Hey thanks for the info, I think you also sold me on ordering a pair.
Lacks Adult Supervision
I've got a red/black bike, and the red/black machined one looks like it was manufactured for the bike. Works like a charm. My commute is about 50 miles one way, so I like the rest I get on my wrist.
Discussion Starter #7
through the site i dont see many options, how'd you get the red and black version? my bikes crimson and black as well..
They're the longer ones with the machined cuts. Red stripe around the base, and matte black on the end.
If I get near a camera tomorrow, I'll send a pic.
Yes, like his, except I got the one with machined grooves in it. I thought it might be easier to roll it with my pinkie finger, since that's usually what I use.
Discussion Starter #14
Got my throttlemeisters yesterday and put them on, install was super easy, maybe 15min. I love how they give you a puller for the stock insert, made life much easier. I also think the look on them is much cleaner and more natural than I thought it'd be. They look like normal-sized custom barends. O and they look sick in the black milled finish on my crimson 05.
Thanks for posting the closeups, Boiler. I completely gaffed off taking pictures of mine. My defense is that I was busy busy bolting on other stuff... I think they look about as good as any bar-end could.
Discussion Starter #18
I installed mine just like they say, took the bolt back out and added locktight, and tightened it enough. My TM still slips, I set it and I slowly tick down about 1mph every second or two. Any ideas?
False. Black bear.
Yup, mine did the same. its just not adjusted 100% correct. took me like 4 rides to get mine right. first off, make sure you didnt forget the friction sleeve. its a pretty important piece. next, loosen the end up, tap it in a little more like you installed it the first time, and tighten it up again. make sure that the plunger has a good amount of force on the grip. where you can still move it, but it takes a little forearm. oh, and when you torque it, dont be shy. mine loosened up on me twice. i really let it have it the next, and its good now.
hope this helps.
I noticed that the instructions err on the side of caution so that you don't find the lock won't disengage. I gave mine a tiny bit more travel after the lock, and it seems to hold.
1 - 20 of 48 Posts
