1 - 20 of 26 Posts
Well since I bought a couple of detectors I figured I better get a mount for the bike. I like the Stem Stand mounts, but $60 to $70 for one I couldn't justify. So $5 for a plug to wire it in and a few minutes to fabricate some aluminum and a liitle powder coat. Hid all the wires and put the plug where it's accessible but inconspicous.
Here are a few pictures. Let me know what you think. The first one is where I put the plug.
Discussion Starter · #2 ·
mount
again
Discussion Starter · #4 ·
#3
Taming the power btwn my legs!
Neat idea. Does it block your view of the guage cluster at all?
Discussion Starter · #6 ·
oops
Discussion Starter · #7 ·
Not at all. It's adjustable forward and backward, which adjusts the hieght as you move it.
No soup for you!
looks clean as hell... where did you put all the wires?
Discussion Starter · #9 ·
I wanted it to be a clean look. If you look to the left of the instrument cluster in the first picture you can see the plug It has a cap on it as not to look out of place when not in use. I used a plug in type because I have two different detectors to use. I ran the wires inbetween the fairing stay brace and the headlight, then under the headlight over to the wiring harness.
Discussion Starter · #11 ·
I don't care if the cops see it theres nothing they can do about it here. And I wanted it to be in the the open because one of the detectors has GPS on it.
Discussion Starter · #15 ·
I thought about that but I wanted to be able to take it with me if I leave the bike and I will switch them out from time to time.
ShInYSiDe <VS> RuBBeRSiDe
Velocity Boy.. that looks real good...
And besides... LIMITED.... you could use that stand as a double....
When you get road fatigued.... you could simply throw the radar in the pocket.. and put the chin on the stand.. Nap time!!
lol.. jk man.. Look s Great.. nice bit o' fabricatin there!
L8R2U
Hey limited does that have a ear piece?
Discussion Starter · #18 ·
Yes the escort 8500 you can use an ear piece or put on one of the little boxes that give one load a$$ alert signal.
My RR tempts me
Can you place a radar detector directly behind a carbon fiber windscreen?
Discussion Starter · #20 ·
You can but it won't be very effective. Even tint can reduce the effectiveness of a detector.
1 - 20 of 26 Posts
