Can I prevent the fans from operating until the engine is running and alternator is providing power?
I have owned and operated an 05 R1 since April 2005, 76,700 miles ago last Saturday. I have rebuilt it after a crash in 2012. My current battery is a YUASA with 190 CCA purchased and installed September 2014, approximately 9K miles ago. I have been working through electrical issues ever since accident rebuild. I have frequently placed battery on slow charger, probably too often. I am worried that I have ruined and expensive battery. My most recent learning however is the battery sounds and behaves as if it has a low charge after bike has been ridden for 40 mins. Usually if I stop for gas, or accidentally stall due to clutch misuse. My assumption is that fans engage whenever the ignition switch is on and the engine temp is 190 or above. I am also assuming that the fans are drawing enough charge that there is not enough battery voltage left to start the bike. Could I be correct? The bike consistently starts when engine is cool.
Are the fans supposed to run if the engine is not engaged and the alternator is not providing power?
I'd appreciate any help at all!
Thanks!
Thanks!
