1 - 5 of 5 Posts
Born to do trackdays
Hi, I'm busy setting up a QBcarbon box.
At idle and initial throttle opening it is fine, but it goes very lean thru 1/4 and 1/2 throttle - until WTO, when it becomes better again.
To help me speed up the process and minimize the times I have to dismantle the whole installation everytime, is this just needle postion or does the float level affect the 1/4 to 1/2 throttle postion also ?
The floats are set at 10 mm and the needle in the middle (3rd).
Discussion Starter #4
Thanks for the responses !
The needles are from the kit they supplied and there's a prominent Factory Pro sticker on the little plastic box.
I'll go one clip up on the needle and see.
Mixture screw - Right is rich and Left is lean ?
Canadian Drinking Team
Isn't there a number on the box?? Call the company.... they'll be able to help you. I know when I had trouble with my Dyno Jet jet kit, I called them and they were very helpful.... had the old girl running like a top. Good luck.
1 - 5 of 5 Posts
