1 - 9 of 9 Posts
I dig my MV Agusta
I am having problems mounting my rear Gladiator, my stock RRP sprocket seems to be to big for the cush drive mount, can someone with experience with RC wheels tell me if I am missing a part or something, or does RC Component wheels require a special sprocket directly from them.
Premium Member
Not sure where you got them but it might be a universal hub... alot of the universal hubs we see requires a busa rear sprocket or a special cut that rc uses for sprockets... There should be a number on the hub if the person you got them from can't get you the right setup then RC should be able to help you... They have descent tech support :fact
measure the hub, if it has a PCD over 5 holes of 100mm and a ID of 76mm it is the same as a marchesini race wheel 99-01! you can then order a sprocket the same as that.:hellobye
1 - 9 of 9 Posts
