The oposite, Nitrogen is innertsevenR said:Fill them with Helium, less unsprung weight !!!
Doesn't nitrogen go BANG quite well ?
:iamwithstjgdonnel said:I'm not sure if it is standard across the country, but my local Costco fills all of their tires with nitrogen. If you ask nicely enough and are a member, I'm sure they would oblige and fill up your tires.
WarehouseR1Ant said:Wouldn't seem like a bad idea. I mean it won't hurt anything but where are you finding a Nitrogen filling tank? I'd be curious to know, because it's true that it wouldn't absorb moisture and fluctuate with temp, and being as I live in Nebraska, I ride in anywhere from 40-95 degrees....that'll run up and down a few psi.
