41 - 56 of 56 Posts
Booya
*bump* any other idea's??? I'm damn tired of this noise, whatever it is!
Still didn't get it fixed?
Were you ever able to find a set of stock rims to eliminate the bearing theory?
Shane loves........me
Discussion Starter · #45 ·
I don't think it's the bearings, cause it spins so freely while it's on a stand. I just hate it becase it's hard to find where it is coming from, there are no rub marks on the forks, lines, fender, calipers or any of the inner panels. I doubt something came loose in the forks, cause that would mess with the turning of the bike. So i'm lost as to where to look
Booya
Hoenstly, I'd still try. Can you just go to a local shop and "borrow" a set of rims for a 10 min ride?
NeeD 4 SpeeD
when this noise happens ,try to pull the brake lever just a litle bit and see if the sound is changing/dissapears.
are u sure that this noise comming from the wheel?
Discussion Starter · #48 ·
That is harder than it seems
I have grabbed the lever, it doesn't pulsate ot vibrate and doesn't make it go away. The forks are going to ATL in January to get re-built and maybe some new steering head bearings. Other than that, I am lost :fact
NeeD 4 SpeeD
hhmmm
i think its the bearings .when u spin it on a stand theres no pressure from the side of the rim , like in a turn.
try to twist the rim back & forward while applying pressure from a side .see if u feel something grinding.
Discussion Starter · #50 ·
hhmmm
:lol Funny you say that because a guy on gsxr.com suggested the same. i tried it this am with no noises other than brake drag.
NeeD 4 SpeeD
maybe thats me also?:snorkel
i think u didnt apply enough pressure :epimp
if i were u , next thing i would do is check the fork with a peice of glass and the axle to see if its bent.
next i would run the bike with only one rotor each time.(gotta put something between the brake pads on the rotorless caliper)
NeeD 4 SpeeD
to check the axle just roll it on some smooth surface .
to check if the forks/triples are bent with a piece of glass :
look at the ugly pic i made:butt .
the red square is the glass , put it on the inner fork tubes as in the pic.
the glass should touch the fork tubes in all 4 corners - the blue circles in the pic, if its touching only 3 then the forks or triples are bent .
Beating a dead horse.
I have somewhat of a similar problem. With my front up on a stand the front wheel spins with with a little bit of brake noise. When my bike is on the ground and I push the bike forward and turn the handle bars to the left, I get a very loud noise. Definitely sounds as if the pads are rubbing slightly...
I looked at the pads and there definitely seems to be enough clearance on the stand though. Any suggestions? I'm running BST's too.
41 - 56 of 56 Posts
