1 - 1 of 1 Posts
Scorpio makes a really nice one that pages you when it goes off!
SR-i900
COMES WITH PERIMETER SENSOR, REMOTE IGNITION DISABLE AND BUILT IN BATTERY BACK UP & BIKE SPECIFIC OEM HARNESS
The all new SR-i900 introduces the next step in motorcycle security by incorporating the convenience of hand free operation to an ultra-compact 2 way FM paging security system designed specifically for the motorcycle industry.
By incorporating RFID to the system is able to know when the remote is walking close to the bike and when its not, allowing the user to never have to reach for the remote to protect the bike.
By utilizing High Frequency FM technology, the SR-i900 transceiver is capable of sending and receiving commands from up to ½ Mile away from the motorcycle.
For its sensing mechanism, the SR-i900 utilizes a built in accelerometer that detects both impact and changes of angles with a high degree of accuracy. It allows the module to be placed in any position or mounting angle and requires no adjustments.
The SR-i900 control module also offers a built in programmable multi tone siren and to ensure durability the module is manufactured to meet OEM specs
For simple installation the SR-i900 offers optional factory style connector kits that simply plug into the motorcycle’s factory wiring harness creating a non-destructive installation.
Perimeter Sensor
3-Stage Perimeter Sensor
Remote activated microwave sensor that detects motion in mass around the motorcycle, protecting saddlebags, luggage and other external accessories.
Anti-Hijack
Remote Ignition Disable
Advanced ignition kill with anti-hijack features that will immobilize the ignition system to prevent "hot wiring". It even allows the user to remotely cut off the engine in case of a hijack attempt.
Easy Install Kits
picConnector Kit
While all Scorpio systems are universal and will fit on any motorcycle, the available OEM connector kits will plug directly into the factory connectors on most bikes, making installation simple and clean.
Details
Battery Back-Up
pic
Optional battery back-up system that allows the pager and siren to operate even if wires are cut or circumvented. Compatible with 06-07 SR-i500 and The SR-i600.
1 - 1 of 1 Posts
