got the scotts installed. everything went smoothly except I was concerned about the 36mm head nut. I torqued it to 85lbs but when the head nut still sits well above the threads. is that normal? Look at pic below. The bracket is sitting flat on the triple tree. I dremeled the triple tree cover so I can keep it on there. So with everything installed correctly, is it normal to have alot of threads above the threaded pipe where the head nut threads too? thanks.
