Hey bro, This may vary per manufacturer but heres what I did, bust out you 1/2 drive socket and ratchet and loosen the swingarm bolt (I did this with the bike on the front and rear stand) take off the swingarm nut ( 27mm socket), put blue loctite on the swingarm threads and screw the slider adapter onto the threads, torque to 90 ft lbs., next put some blue loctite on the bolt for the slider and screw that into the swingarm adapter, should be all set bro, good luck!!
Joe
