Yes, the wheel was put on balance machine today and it was wobbling from left to right. It is bent. I will be buying FZ10 wheels since they are almost third the price of the r1.It should be replaced.
You could check the runout with a dial indicator and see if it is inside spec, but, if you can see it with your eye, it's most likely done.
I can neither confirm nor deny cross platform compatibility of the sprocket. One thing you could do is check the Yamaha part number and see if it is a match.Yes, the wheel was put on balance machine today and it was wobbling from left to right. It is bent. I will be buying FZ10 wheels since they are almost third the price of the r1.
From reading the forums, I know the FZ/MT10 2017 wheels will fit the R1 2016. Do you know if the I can put the r1 sprocket on FZ wheel?
I looked it up, the gen 3 FZ10/MT10 2016+ and r1s rims will fit 15+ r1. The cush drive, sprocket carrier, and sprocket has to be retained from the mt10 or r1s as they are incompabitable with the 2015+ r1.I can neither confirm nor deny cross platform compatibility of the sprocket. One thing you could do is check the Yamaha part number and see if it is a match.
Cool plan!!Yes, the r1 and r1m are magnesium cast and the MT10/R1S is aluminum cast. My plan is to change both front and rear rims. I ended up getting a set of used blue R1M rims.
