1 - 7 of 7 Posts
Poe said:
19mm hex for the front......32mm socket for the rear.
Don't rememember where I orderd it from though it was not more than 20.00 for a 19mm 1/2" drive.
Thanks! I got the tire off a long time ago and lost the tools so I couldnt remember what the size was, thanks.
Go get a bolt(with19mm head) and 2 nuts from the hardware store. Tighten the nuts together on the bolt and use the head of the bolt to loosen the axle. Cost about $2.
Like The Rising Phoenix
i've always just left the pinch bolts in place... loosened the axel hold bolt..... and done.... no need for any special hex tool.... actually a service manager at a dealership tought me this trick
you can also use a 5/8 standard sparkplug socket...turn it around and put an extension in through the big end, the other end is 19mm, works perfectly and you can use your torque wrench. FREEBIE
Two excellent tips there fellas! Thanks a ton!
1 - 7 of 7 Posts
