The ohlins is a good unit..... (I had the ohlins damper on my last bike...)
But --- the Ohlins does not have an 'intelligent' circuit in the oil flow.... its either tight or loose. In the event of a major slapper, the ohlins DOES NOT tighten up any more than its current setting. (my opinion being....the Ohlins is still better than stock and a great unit....)
If you want a damper that you can be set on its loosest setting AND tighten up in the case of a slapper.....
GPR, Scotts/Ohlins rotary damper, Hyperpro RSC, etc. etc.
(they sort of work like a front fork Gold Valve but in the opposite way, when the rate of slap changes.... a different firmer damping rate comes in, unlike the Gold Valve in which a softer rate comes in at high-speed damping)
I've owned the Scotts Rotary on my Honda 954RR....it was an awesome unit. (and designed by Ohlins mind you...)
