1 - 2 of 2 Posts
Today I managed to put together a servo eliminator following the instructions in post #7 & #8 from this post: HOW TO: DIY EXUP Motor Eliminator
Here are a few photos. I didn't have 1.5KΩ resistors so I put two 600-ish Ω resistors in series for a total of 1.2KΩ and they seem to work just fine. I chopped the connectors off the obviously dead servo motor and wired them into the PCB. This is a form of 'veroboard' where rows of 5 holes are connected together. It takes a little thought but proves solid results.
For 'packaging' I used a technique that I've been taught for waterproofing connectors. Using initially self-amalgamating tape - stretched and applied. This tape sticks to itself and then provides a sticky base for the electrical tape top-layer - also stretched as applied. A cable tie around the cables before starting, which is itself then wrapped, helps with the waterproofing.
Tested in the garage it seems to work fine - good excuse to check it out on the roads tomorrow with a 'test ride' ;).
Regards, Mark.
Circuit component Electrical wiring Technology Cable Wire
Veroboard based circuit
Wood Gesture Art Creative arts Triangle
First layer of self-amalgamating tape, followed by another wrap the other way.
Wood Natural material Musical instrument Fashion accessory Metal
Final wrap - several layers of stretched electrical tape
Wood Ruler Audio equipment Hat Office supplies
Self-amalgamating tape.
Wood Fashion accessory Metal Creative arts Liver
Finished product, cable tied into a suitable position.
1 - 2 of 2 Posts
