1 - 8 of 8 Posts
I went to change the oil in my bike today and can't get to the oil drain bolt with a socket wrech because of the way the termi exhaust is made. The exhaust pipe is right under the oil drain bolt, so now I have to take apart the entire exhaust just to change the oil. Thanks Alot Termignoni! :mad:
Drop a gear and Disappear!
box end wrench or craftsman makes a wrench / socket combination wrench with a swivel socket on the back end that should work
Discussion Starter · #4 ·
Thank Guys, but the exhaust pipe is so close to the oil drain bolt that I can't fit the box end of a regular wrench between the two without loosen the exhaust. The only way that works is to use the open end of a regular wrech but I feel like its real easy to stripp the bolt that way.
1/4 mile in X.XX seconds?
alot of times its easy to loosen it at the next attachment that usually gives you enough play to get a grip on it....with out taking off the headers....
hey where are you at in va....
1 - 8 of 8 Posts
