1 - 9 of 9 Posts
I need more money.
I have to try like 2 or 3 times, then it's starts.
It's only happenning after try to start it over night.(in the morning)
it is no cold here yet and the weather is nice.
Does your bike start on first shot ?
this issue is bothering me.
thanks.
LoneRone
Same here Lawnboy, mine never starts first try no matter if i let the fuel pump prime or not, it will only start first shot if it has been running and is still warm, mines an 02' I guess its the same with the 03's
-Joe
GO CHIEFS!!!
Yup, mine has always been the same way. Takes a few tries to start in the morning, but then start instantly after that...
- BA
USMC/0369 1986-2008
:riding This is NORMAL, let it prime then bumb it. Then bump it again. Worst case scenario you have to bump it 3 times. My 02 does it every morning. Then it will lop until 128 degrees.
Don't throttle it until it warms:jump
Super Moderator
If your starting for the first time with a cold engine to go riding
try this. Let everything prime up then hold in the clutch then
press the start button. After it starts release the clutch. This
helps the bike on a cold engine. Once it's warmed up start it up
like you always do.
1 - 9 of 9 Posts
