61 - 80 of 116 Posts
All electrical connectors?
Even the ones for each spark plug and all the sensors?
I would guess you didn't screw with the ECU connection?
I have 2 tubes and since I have all my plastic off and the tank raised this would be a good time.
I guess I should also do the plug boots. That's the exact reason they sell the little packs of dielectric at the auto parts when you get new plugs for your car.
I used it on the plug boots, coil connections, sensors, and other connections in that area while I had the tank up to replace the plugs.
The only problem I had was keeping the front wheel on the ground when I went riding yesterday. hehe
R190-`Tyre Fryer`
does anyone know if di electric grease is the same white paste used as heat sink grease on computers? also someone told me it is hella carcinogenic, but that must be why its so good :)
No, it's a different compound.
Okay, I'll bite. What's "heat sink grease" and how is it used?
R190-`Tyre Fryer`
heat sink grease is also called thermal paste in computer circles.. on your chips especially the CPU and GPU there is a aluminium heat sink mounted.
the thermal paste is very similar in appearance to di electric grease and is pasted onto the chip surface to ensure good contact with the heat sink face
In laymen's terms, it's a heat transfer agent. :lol :lol
The difference between the two is that dielectric grease doesn't harden, while the heat sink goo does.
what grease would be appropriate to make it easier to plug and unplug my usb and firewire things? I was thinking a dab of dielectric grease might do it, but I would hate for things to get messy.
Mark
(a layman)
Just double checking, is this the right stuff???
Link
We're in the pipe, 5 by 5
Link
Blinking 'eck, click back a few pages..
All details posted to Chuck on this post..
RS Silicon - Dielectric Grease
RS Components http://rswww.com
DEF59.10 silicone grease,100gm tube £3.83
RS Part Number : 494-124
doin it with the r...
so im going to put this stuff on the connections only right? not on the wires themself correct? sorry if im asking a dumb question.
Discussion Starter #76
yup.
No need to put some everywhere though...charging system connectors and all the ones at the front+those that could collect water when you wash the bike.
Life's a Bitch & I'm her Pimp.
Hey guys, haven't been on here in quite a while, but I figured this would be a good post for me to jump in on. (I work as an engineer for Lexus, and will be around to jump in on more of the technical and theoretical questions).
Silicon Dielectric grease is designed to lubricate and seal your electrical connections. It also has plenty of other uses, I personally use it to lube rubber seals (good sealing grease for dirtbike air filters). The standard dielectric grease I use is 3M Silicon Paste, available in a 8oz can. And I use it on every connector on my bikes and cars, including battery terminals, secondary (spark plug) wires, and light bulbs.
The grease is a dielectric, meaning insulator. It does not allow electricity to flow through it. However, when used on a good connector, the terminals will displace the grease and allow proper current flow. The reason to use an insulating grease is to keep environmental contaminents out, and voltage in. If you have ever seen a spark plug with carbon tracings down the porcelain, you understand how voltage can leak from a connector.
As previously mentioned, apply a liberal amount to the connector before fastening. I usually prefer to just toss on a rubber glove and scoop it with my finger. The grease will fill the connector, keeping water out and preventing corrosion. I also recommend applying dielectric grease to all light bulbs before installing to prevent corrosion (on old twist-in base automotive bulbs, use the brush to cover all of the exposed metal, then plop a little extra into the socket).
Oh yeah, I also recommend it on the slide pins of any automotive floating calipers. It will keep the pins free, and won't swell the rubber boots or bushings.
Personally, I get it at work. And we buy it from an industrial chemical distributor. However, I searched google for "3m silicone paste 08946", and found plenty of places selling it (it also looks like there's a bunch on ebay). Oh yeah, 08946 is the part number on the can (that's why i put it in the google search).
