take exception all you want, it's the plain truth.
It has nothing to do with economy, or performance or non performance engines. It's a simple matter of understanding engines.
weither it's performance oriented or not, you don't want the motor to ping. Thats terribly bad for an engine. So what you want to do is use the LEAST octane that does not kock or ping. That means it it pings on 87 then you try 89. If it stops pinging then thats your fuel choise. It's not complicated.
Most every modern bike I have dealt with runs fine on 87 octane if it's stock. Not all, but most.
I have built several engines for motorcycles now that have been between 13 to 1 and 13.5 to 1 and they all have run with out pinging on 87 octane pump fuel.
You won't be hearing ping at 175mph, as that would be topped out in 6th on your bike (and a speed you won't be seeing on Heartlands front straight, though it humored me) as like I said before you will get ping at lower and mid rpms first. Its very hard to miss.
at higher rpm there is just not time for the fuel to ping. At high load and lower rpm then you get ping. You have high cylinder pressure (which is pressure and heat) and the resistance of the tall gear at an non optimal rpm for aceleration.
If you want to use 91 octane then thats fine. You are welcome to do it.
Please wave hi to the G1K's that pass you, I might have built one of their motors
When you get back in the pits, see what fuel they are using.
